Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Flip the Apple TV over so that the bottom of the unit is facing up.
  • Flip the Apple TV over so that the bottom of the unit is facing up.
  • You need to remove the rubber base to get access to the screws.
  • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
  • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
  • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
  • Repeat the procedure described above until the rubber base has been completely removed.
Insertar traducción aquí
