Saltar al contenido principal
Inglés
Español
Paso 11
The AMOLED DotDisplay—one of the Mi 11's power eaters—shines with up to 120 Hz adaptive refresh rate and a WQHD+ resolution of 3200 x 1440 pixels (~515 ppi). It also packs a blistering 480 Hz touch sampling rate. Curved displays can create a novel "infinity edge" look, but they are usually a pain to remove. But with some encouragement from our iMac Opening Wheel, the display comes off splinter-free—should we thank the lack of an IP rating for that? The ultra-thin optical in-display fingerprint sensor by Goodix hides under the display and requires some gentle pulling to come free.
  • The AMOLED DotDisplay—one of the Mi 11's power eaters—shines with up to 120 Hz adaptive refresh rate and a WQHD+ resolution of 3200 x 1440 pixels (~515 ppi). It also packs a blistering 480 Hz touch sampling rate.
  • Curved displays can create a novel "infinity edge" look, but they are usually a pain to remove. But with some encouragement from our iMac Opening Wheel, the display comes off splinter-free—should we thank the lack of an IP rating for that?
  • The ultra-thin optical in-display fingerprint sensor by Goodix hides under the display and requires some gentle pulling to come free.
  • Lastly, we'll peel apart the Mi 11's vapor chamber cooling system, which combines with these multiple layers of graphite and AI to keep this machine cool. Copper and graphite are both very efficient at offloading heat, so we're not sure how much the AI actually contributes here—but sure, why not!
La pantalla AMOLED DotDisplay -una de las más potentes del Mi 11- brilla con una frecuencia de actualización adaptativa de hasta 120 Hz y una resolución WQHD+ de 3200 x 1440 píxeles (~515 ppi). También tiene una impresionante tasa de muestreo táctil de 480 Hz.
Las pantallas curvas pueden crear un novedoso aspecto de "borde infinito", pero suelen ser un dolor de cabeza. Pero con un poco de ayuda de nuestra rueda de apertura del iMac, la pantalla se desprende sin astillas -¿debemos agradecer la falta de una clasificación IP por ello?
El sensor óptico de huellas digitales ultrafino de Goodix se esconde debajo de la pantalla y hay que tirar con cuidado para liberarlo.
Por último, vamos a desmontar el sistema de refrigeración de la cámara de vapor del Mi 11, que se combina con estas múltiples capas de grafito y AI para mantener esta máquina fresca. Tanto el cobre como el grafito son muy eficientes a la hora de descargar el calor, así que no estamos seguros de cuánto contribuye realmente la IA aquí, pero claro, ¡por qué no!
