Saltar al contenido principal
Inglés
Español
Paso 9
We didn't exactly miss the weird cable snakes encountered in the Mate 30 Pro, but it seems the time has come to face a similar threat in the Mi 11. These three coax cables running down to the daughterboard are threaded over and under each other, making them annoying to remove. In an ideal world, they'd simply float out of the way, like in this photo that we totally didn't stage. Last bits before the battery: this small linear actuator vibration motor, and the daughterboard. PS, while there's no official IP rating for the Mi 11, we spot a decent amount of rubber gasketry around the speaker and charging port areas.
  • We didn't exactly miss the weird cable snakes encountered in the Mate 30 Pro, but it seems the time has come to face a similar threat in the Mi 11.
  • These three coax cables running down to the daughterboard are threaded over and under each other, making them annoying to remove. In an ideal world, they'd simply float out of the way, like in this photo that we totally didn't stage.
  • Last bits before the battery: this small linear actuator vibration motor, and the daughterboard. PS, while there's no official IP rating for the Mi 11, we spot a decent amount of rubber gasketry around the speaker and charging port areas.
  • Both the USB-C charging port and the SIM card reader are soldered to the daughterboard. Thankfully it's easy enough to reach, and the part itself doesn't look too expensive (although ideally we’d still prefer separate components to make individual repairs easier).
No echamos de menos precisamente las extrañas serpientes de cables que encontramos en el Mate 30 Pro, pero parece que ha llegado el momento de enfrentarse a una amenaza similar en el Mi 11.
Estos tres cables coaxiales que bajan hasta la placa hija están enhebrados por encima y por debajo de los demás, lo que hace que sean molestos de quitar. En un mundo ideal, simplemente flotarían fuera del camino, como en esta foto que no hemos puesto en escena.
Las últimas piezas antes de la batería: este pequeño motor de vibración del actuador lineal, y la placa secundaria. P.D.: aunque no hay una clasificación oficial de IP para el Mi 11, vemos una buena cantidad de juntas de goma alrededor de las zonas del altavoz y del puerto de carga.
Tanto el puerto de carga USB-C como el lector de tarjetas SIM están soldados a la placa base. Afortunadamente es bastante fácil de alcanzar, y la pieza en sí no parece demasiado cara (aunque idealmente seguiríamos prefiriendo componentes separados para facilitar las reparaciones individuales).
