Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Gently lift the controller port board out of its recess within the bottom case. Do not completely remove the controller port board. It is still attached via a ribbon cable.
  • Gently lift the controller port board out of its recess within the bottom case.
  • Do not completely remove the controller port board. It is still attached via a ribbon cable.
  • Pull the controller port ribbon cable straight away from its socket on the controller port board.
  • Remove the controller port board out of the bottom case.
Insertar traducción aquí
