Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 9
Paso 9
Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch. Carefully lift the power board. You should now see the power board connector attached to the power board.
  • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
  • Carefully lift the power board. You should now see the power board connector attached to the power board.
  • Pull the power board connector straight to lift it out of its socket on the power board.
Insertar traducción aquí
