Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 9
Use an opening pick to lever out the antenna cable assembly in the areas shown. Don't slide the opening pick from side to side, as there are two display cables that could be damaged in the way. Don't slide the opening pick from side to side, as there are two display cables that could be damaged in the way.
Pry up the antenna cable assembly
  • Use an opening pick to lever out the antenna cable assembly in the areas shown.
  • Don't slide the opening pick from side to side, as there are two display cables that could be damaged in the way.
Usa una púa de apertura para sacar el ensamblaje del cable de la antena en las áreas que se muestran.
No deslices la púa de apertura de lado a lado, porque hay dos cables de pantalla que pueden dañarse.
