Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 11 guías que incluyen este paso.
Inglés
Español
Paso 3
If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen. Place a suction cup as close to the right edge of the screen as possible. Lift the suction cup with a strong steady force.
Insert an opening pick
  • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  • Place a suction cup as close to the right edge of the screen as possible.
  • Lift the suction cup with a strong steady force.
  • Insert the tip of an opening pick into the screen seam no more than 1 mm.
Insertar traducción aquí
