Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Gently lift the metal casing from the motherboard. Then lift the motherboard from the plastic outer shell.
  • Gently lift the metal casing from the motherboard.
  • Then lift the motherboard from the plastic outer shell.
  • You should have three separate components: The metal casing, the motherboard and the top half of the outer shell of the PS2.
Con suavidad levanta la carcasa metálica de la placa base y la placa base de la carcasa de plástico. Después de este paso, deberías tener tres componentes por separado: La carcasa metálica, la placa base y la mitad de la carcasa plástica de tu PS2.
[* black] Gently lift the metal casing from the motherboard andmotherboard.
[* black] Then lift
the motherboard from the plastic outer shell. After this step, you
[* icon_note] You
[* black] Then lift
[* icon_note] You
