Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 4
With tweezers, gently detach all three ribbons from the motherboard terminal.  Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  • With tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side.
  • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
Insertar traducción aquí
