Saltar al contenido principal
Inglés
Español
Traduciendo paso 2
Paso 2
Press and hold the Shift + Option keys on your Mac's keyboard and click the Bluetooth symbol in the top-right corner of the macOS menu bar. Locate the revealed Debug submenu and hover your mouse cursor over it. If you have problem with a connected Bluetooth device you can reset the Bluetooth module entirely from the Debug menu. This will wipe the Bluetooth configuration, reset the Bluetooth hardware, and disconnect any connected Bluetooth devices.
  • Press and hold the Shift + Option keys on your Mac's keyboard and click the Bluetooth symbol in the top-right corner of the macOS menu bar.
  • Locate the revealed Debug submenu and hover your mouse cursor over it.
  • If you have problem with a connected Bluetooth device you can reset the Bluetooth module entirely from the Debug menu. This will wipe the Bluetooth configuration, reset the Bluetooth hardware, and disconnect any connected Bluetooth devices.
  • If you want to fix a problem with connected Apple device then try the second menu. It works only the device is connected an only for Apple devices!
Insertar traducción aquí
