Saltar al contenido principal
Inglés
Español
Paso 6
Unmasked, the iPhone 12 Pro Max's primary (wide-angle) sensor is... large. Not unlike the phone it lives in. Sometimes we're skeptical when a "Pro" feature only makes it into a larger, more expensive model. But there's a decent chance this sensor wouldn't fit in the cramped corner of the smaller iPhone 12 Pro without compromises.
  • Unmasked, the iPhone 12 Pro Max's primary (wide-angle) sensor is... large. Not unlike the phone it lives in.
  • Sometimes we're skeptical when a "Pro" feature only makes it into a larger, more expensive model. But there's a decent chance this sensor wouldn't fit in the cramped corner of the smaller iPhone 12 Pro without compromises.
  • This sensor dwarfs the iPhone 12's. It's 47% larger but with the same 12 MP resolution, so each pixel is larger and captures more light.
  • This sensor also has that other trick up its sleeve: sensor-shift image stabilization.
  • That's a technology many modern DSLR and mirrorless cameras use. When your hands shake, there are two main ways to stabilize the image: you can move the lens, or you can move the sensor.
  • Most smartphones that tout image stabilization use lens-based optical image stabilization (OIS) to smooth out jitters. Many internet battles have been fought over which stabilization technique works best in professional cameras.
  • Since Apple went out of their way to bring sensor-shift to the iPhone, either they think that's the way to go, or perhaps they just couldn't adequately stabilize the larger version of their new f/1.6 lens.
Desenmascarado, el sensor principal (gran angular) del iPhone 12 Pro Max es... grande. No es muy diferente del teléfono en el que vive.
A veces somos escépticos cuando una función "Pro" sólo lo convierte en un modelo más grande y más caro. Pero hay una buena posibilidad de que este sensor no quepa en la estrecha esquina del pequeño iPhone 12 Pro sin compromisos.
Este sensor empequeñece al iPhone 12. Es 47% más grande pero con la misma resolución de 12 MP, así que cada píxel es más grande y captura más luz.
Este sensor también tiene otro truco bajo la manga: estabilización de la imagen por desplazamiento del sensor.
Esa es una tecnología que muchas cámaras modernas DSLR y sin espejo usan. Cuando las manos tiemblan, hay dos formas principales de estabilizar la imagen: puedes mover la lente, o puedes mover el sensor.
La mayoría de los teléfonos inteligentes que promocionan la estabilización de la imagen utilizan la estabilización óptica de la imagen (OIS) basada en lentes para suavizar los nervios. Se han librado muchas batallas en Internet sobre qué técnica de estabilización funciona mejor en las cámaras profesionales.
Desde que Apple se esforzó en llevar el cambio de sensor al iPhone, o bien piensan que es el camino a seguir, o tal vez simplemente no pudieron estabilizar adecuadamente la versión más grande de su nueva lente f/1.6.
