Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard. Disconnect the secondary interconnect cable from the motherboard. Disconnect the secondary interconnect cable from the motherboard.
Remove the interconnect cables
  • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
  • Disconnect the secondary interconnect cable from the motherboard.
Usa el extremo puntiagudo del spudger para desconectar el cable de interconexión de la placa madre.
Desconecta el cable de interconexión de la placa madre.
+[title] Remove the interconnect cables
[* black] Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
[* black] Disconnect the secondary interconnect cable from the motherboard.
