Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Place the flat end of a supdger in the small gap between the plastic frame and the battery, opposite to the display cable. Carefully lever the battery up and out of its recess. The battery is adhered to the core with light adhesive, so take your time.
Lever up the battery
  • Place the flat end of a supdger in the small gap between the plastic frame and the battery, opposite to the display cable.
  • Carefully lever the battery up and out of its recess.
  • The battery is adhered to the core with light adhesive, so take your time.
  • Don't try to remove the battery completely yet, as its connector is still adhered to the core.
Coloca el extremo plano de un supdger en el pequeño hueco entre el marco de plástico y la batería, opuesto al cable de la pantalla.
Con cuidado levanta la batería y sácala de su hueco.
La batería está adherida al núcleo con un adhesivo ligero, así que tómate tu tiempo.
No intentes quitar la batería por completo todavía, ya que su conector sigue adherido al núcleo.
