Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 8
Once you've aligned the bottom half of the adhesive strip, peel the longer piece of backing out from behind the strip. If the bottom half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  • Once you've aligned the bottom half of the adhesive strip, peel the longer piece of backing out from behind the strip.
  • If the bottom half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
Una vez que hayas alineado la mitad inferior de la tira adhesiva, quita el trozo más largo de la parte trasera de la tira.
Si la mitad inferior no está bien alineada, puedes despegarla con cuidado y volver a pegarla antes de despegar la tira de respaldo inferior. Asegúrate de usar la punta del spudger para anclar la parte superior.
