Saltar al contenido principal
Inglés
Español
Traduciendo paso 6
Paso 6
Lift up the wiper blade and rotate the wiper 90 degrees. There will be some resistance, however you should not need to use a lot of force. If it does not come off easy you may be doing it wrong. There will be some resistance, however you should not need to use a lot of force. If it does not come off easy you may be doing it wrong.
  • Lift up the wiper blade and rotate the wiper 90 degrees.
  • There will be some resistance, however you should not need to use a lot of force. If it does not come off easy you may be doing it wrong.
Insertar traducción aquí
