Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 2
Pry off the back cover using the plastic opening tool. Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
  • Pry off the back cover using the plastic opening tool.
  • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
  • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
  • Do not use a metal tool when working with your device.
Insertar traducción aquí
