Saltar al contenido principal
Inglés
Español
Paso 13
Slide the flat end of a spudger under the middle portion of the ribbon cable to separate the adhesive holding it to the rear case. Slide the flat end of a spudger under the middle portion of the ribbon cable to separate the adhesive holding it to the rear case.
  • Slide the flat end of a spudger under the middle portion of the ribbon cable to separate the adhesive holding it to the rear case.
Deslice el extremo plano de un spudger debajo de la parte central del cable de cinta para separar el adhesivo que lo sujeta a la carcasa trasera
