Saltar al contenido principal
Inglés
Español
Paso 7
Remove the two 2.1 mm Phillips screws securing the metal bracket to the rear case. Remove the metal bracket from the rear case. Remove the metal bracket from the rear case.
  • Remove the two 2.1 mm Phillips screws securing the metal bracket to the rear case.
  • Remove the metal bracket from the rear case.
Retire los dos tornillos Phillips de 2,1 mm que sujetan el soporte de metal a la caja trasera.
Retire el soporte de metal de la caja trasera.
