Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 153 guías que incluyan este paso.
Inglés
Español
Paso 13
This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly. Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
  • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
  • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
  • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
Este paso requiere que mueva la selección de apertura a lo largo del borde inferior derecho del panel frontal. La antena Wi-Fi está muy cerca de la esquina y se corta fácilmente si el adhesivo se suelta incorrectamente.
No quite por completo la selección de debajo del cristal delantero, pero tire de él sólo un poco para que ~ 1/8 "de la punta está todavía debajo del cristal frontal.
Deslice la punta de la selección de apertura a lo largo del borde inferior del iPad, liberando el adhesivo sobre la antena Wi-Fi.
[* icon_caution] This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
-[* icon_note] Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" of the tip is still under the front glass.
+[* icon_note] Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
[* black] Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
