Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Levanta la pantalla del marco y sácala del iMac.
Puede que sea necesario levantarla lentamente por un lado para despegar el adhesivo restante.
Ten mucho cuidado al manipular la pantalla, es grande, pesada y está hecha de vidrio.
Después de cortar el adhesivo, no se puede utilizar para volver a sellar la pantalla en su lugar. Sigue esta guía para reemplazar las tiras adhesivas que fijan la pantalla a la carcasa trasera.
[* black] Lift the display up from the frame and remove it from the iMac.
[* black] It may be necessary to slowly lift from one side to peel against the remaining adhesive.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass.
[* icon_reminder] After the adhesive is cut, it cannot be used to re-seal the display in place. Follow [guide|136337|this guide|new_window=trueguide|137411|this guide] to replace the adhesive strips that secure the display to the rear enclosure.
