Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath. Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful. Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
Remove the battery
  • If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
  • Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
  • Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
Si las lengüetas de la batería se rompieron durante la extracción, inserte un pico de apertura en el borde superior derecho de la batería, cortando el adhesivo por debajo.
Aunque hayas retirado las tres lengüetas de la batería, puede resultar útil utilizar una púa de apertura para sacar la batería.
No insertes la púa de apertura en el cable sensor de agarre ni en ningún lugar debajo de él, ya que la púa puede dañar el cable flexible del puerto de carga situado debajo de la batería.
[title] Remove the battery
[* black] If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
[* icon_note] Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
- [* icon_caution] Don't insert the opening pick on or anywhere below the [https://d3nevzfk7ii3be.cloudfront.net/igi/PJK1RXUEONc5jZDF.full|grip sensor cable], as the pick can damage the charge port flex cable located underneath the battery.
+ [* icon_caution] Don't insert the opening pick on or anywhere below the [https://d3nevzfk7ii3be.cloudfront.net/igi/PJK1RXUEONc5jZDF.full|grip sensor cable|new_window=true], as the pick can damage the charge port flex cable located underneath the battery.
