Saltar al contenido principal
Inglés
Español
Paso 7
Although the OnePlus Nord carries no official IP rating, it does use rubber connector gaskets found in the IP68-certified OnePlus 8 Pro—so it may have inherited some water and dust resistance. Gaskets are cheap, but the actual IP testing and certification costs a pretty penny, which OnePlus decided to forego this time. Good on them for including a little protection, even if it's not advertised as such. Remove two Phillips screws and the motherboard lifts out next, revealing some thermal paste on the back.
  • Although the OnePlus Nord carries no official IP rating, it does use rubber connector gaskets found in the IP68-certified OnePlus 8 Pro—so it may have inherited some water and dust resistance.
  • Gaskets are cheap, but the actual IP testing and certification costs a pretty penny, which OnePlus decided to forego this time. Good on them for including a little protection, even if it's not advertised as such.
  • Remove two Phillips screws and the motherboard lifts out next, revealing some thermal paste on the back.
  • The thermal paste is plopped onto the graphite foil covering the chips, which have additional thermal paste of their own underneath. On the opposite side, the paste transfers heat into a copper element running behind the motherboard and down between the battery and display.
Aunque el OnePlus Nord no tiene una clasificación oficial de IP, utiliza las juntas de goma del conector que se encuentran en el OnePlus 8 Pro con certificación IP68, por lo que puede haber heredado cierta resistencia al agua y al polvo
Las juntas son baratas, pero las pruebas y la certificación de la propiedad intelectual cuestan una buena cantidad de dinero, por lo que OnePlus decidió no hacerlo esta vez. Bien por ellos por incluir un poco de protección, aunque no se anuncie como tal.
Sólo dos tornillos Phillips más y la placa madre se levanta revelando algo de pasta térmica en la parte posterior.
La pasta térmica se deposita en la lámina de grafito que cubre los chips, que tienen una pasta térmica adicional propia debajo. En el lado opuesto, la pasta transfiere el calor a un elemento de cobre que corre detrás de la placa madre y baja entre la batería y la pantalla.
