Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 2
Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module. Insert an opening pick between the midframe and the display module on the right edge of the phone. Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
  • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
  • Insert an opening pick between the midframe and the display module on the right edge of the phone.
  • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
Inserta una púa de apertura entre el marco medio y el módulo de pantalla en el borde derecho del teléfono.
Desliza la púa de apertura en la esquina inferior derecha para abrir las abrazaderas de plástico del módulo de pantalla.
+[* icon_caution] Make sure to insert the opening pick [link|https://guide-images.cdn.ifixit.com/igi/1SvcxAEamwNQ1QuK.full|between the midframe and the display module|new_window=true] and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
[* black] Insert an opening pick between the midframe and the display module on the right edge of the phone.
[* black] Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
