Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the flat end of a spudger to loosen and pry up the mildly glued NFC antenna. Carefully fold the NFC antenna in the direction of the upper edge of the watch.
  • Use the flat end of a spudger to loosen and pry up the mildly glued NFC antenna.
  • Carefully fold the NFC antenna in the direction of the upper edge of the watch.
Usa el extremo plano de un spudger para aflojar y levantar la antena NFC ligeramente pegada.
Dobla cuidadosamente la antena NFC en dirección al borde inferior del reloj.
[* black] Use the flat end of a spudger to loosen and pry up the mildly glued NFC antenna.
-[* black] Carefully fold the NFC antenna in the direction of the bottom edge of the watch.
+[* black] Carefully fold the NFC antenna in the direction of the upper edge of the watch.
