Saltar al contenido principal
Inglés
Español
Traduciendo paso 6
Paso 6
With the drive upside down, gently pull back on the ribbon cable retaining tabs and pull out the ribbon cable. There are 2 plastic tabs and 1 post holding the board in place. Lift up on the post, slide PCB to the left and then forward. Reverse process to reattach PCB
Separate PCB
  • With the drive upside down, gently pull back on the ribbon cable retaining tabs and pull out the ribbon cable.
  • There are 2 plastic tabs and 1 post holding the board in place. Lift up on the post, slide PCB to the left and then forward.
  • Reverse process to reattach PCB
  • Rotate PCB right and place to the side
  • There's just enough length in the cable to place the board in a PCB holder to replace capacitors.
Insertar traducción aquí
