Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 3
If the left speaker is already disconnected, skip this step. Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker. With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  • If the left speaker is already disconnected, skip this step.
  • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
  • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
Desliza la punta de un spudger debajo del cable del altavoz y haz una palanca hacia arriba para desconectar el altavoz.
Con el conector desconectado, desliza la punta plana de un spudger bajo el cable para separar el adhesivo que asegura el cable a la placa lógica.
-[* black] Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
+[* icon_note] If the left speaker is already disconnected, skip this step.
+[* black] Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
[* black] With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
