Saltar al contenido principal
Inglés
Español
Paso 20
Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step. Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis. Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
Remove the screen
  • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
  • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
  • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
Mantén un agarre firme tanto en la pantalla como en el cuerpo principal del MacBook Pro. Cualquiera de las dos mitades puede caer inesperadamente durante este paso.
Empuje ambas mitades del MacBook Pro juntas para que las bisagras se puedan levantar y queden libres de sus huecos en el chasis.
Empuja la carcasa principal del MacBook Pro hacia ti mientras tiras de la pantalla hacia ti para separarla.
