Saltar al contenido principal
Inglés
Español
Paso 19
Use a T8 Torx driver to remove the two remaining 5.0 mm hinge screws (one from each hinge). Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly. Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
Remove the remaining hinge screws
  • Use a T8 Torx driver to remove the two remaining 5.0 mm hinge screws (one from each hinge).
  • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
Usa un destornillador T8 Torx para quitar los dos tornillos restantes de 5.0 mm de la bisagra (uno de cada bisagra).
Quita el último tornillo de la parte superior, usando una mano para sujetar ambas mitades del MacBook Pro para asegurarte de que no se separen y caigan de forma inesperada.
