Saltar al contenido principal
Inglés
Español
Paso 13
Use a T8 Torx driver to remove two 5.0 mm screws from each hinge (four screws total). Each hinge has a third screw, which you should leave in place for now.
Remove some of the hinge screws
  • Use a T8 Torx driver to remove two 5.0 mm screws from each hinge (four screws total).
  • Each hinge has a third screw, which you should leave in place for now.
Usa un destornillador T8 Torx para quitar dos tornillos de 5.0 mm de cada bisagra (cuatro tornillos en total).
Cada bisagra tiene un tercer tornillo, que debes dejar en su lugar por ahora.
