Saltar al contenido principal
Inglés
Español
Paso 11
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink. During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it. During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
  • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
  • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
Retira cuidadosamente el ensamblaje de la antena, mientras que simultáneamente extraes el paquete de cables de la antena de debajo del disipador de calor.
Durante el reensamblaje, junta suavemente el conjunto de cables y guíalo bajo el disipador de calor hasta la posición correcta en la placa. Si es necesario, usa tus herramientas para ayudar a guiarlo, pero no lo fuerces.
