Saltar al contenido principal
Inglés
Español
Paso 10
Use an opening pick to pry up the antenna assembly and separate it from the MacBook Pro. Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables. Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables.
  • Use an opening pick to pry up the antenna assembly and separate it from the MacBook Pro.
  • Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables.
Utiliza una púa de apertura para levantar el ensamblaje de la antena y separarlo del MacBook Pro.
Ten cuidado con los delicados cables planos en la sección media. Evita deslizar la púa de un lado a otro para no dañar los cables.
