Saltar al contenido principal
Inglés
Español
Paso 7
Disconnect all three antenna cables by prying each one straight up from its socket. Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
  • Disconnect all three antenna cables by prying each one straight up from its socket.
  • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
  • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
Desconecta los tres cables de la antena haciendo palanca en cada uno de ellos.
Desliza tus pinzas o el extremo plano de tu spudger debajo de cada cable hasta que esté cerca del zócalo, y luego gíralo suavemente o haz una palanca para desconectarlo.
Para volver a conectar cada cable, alinea el conector directamente sobre su zócalo y luego presiona hacia abajo para que encaje en su lugar.
