Saltar al contenido principal
Inglés
Español
Paso 4
Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side). Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
Remove the hinge covers
  • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
Utiliza un destornillador T3 Torx para quitar los cuatro tornillos de 2 mm de las tapas de las bisagras (dos tornillos en cada lado).
