Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner. Remove the 27mm screw using the T6 Torx screwdriver.
  • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
  • Remove the 27mm screw using the T6 Torx screwdriver.
  • If there is a red Palm sticker covering this screw, puncture it to access the screw.
Insertar traducción aquí
