Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
The face plate can now be removed from the body of the radio.  Gently pull on the face plate to separate it from the radio.  It might require a little bit of wiggling to remove. Be careful when removing the front panel.  The connectors inside are known to have weak solder joints, and it is possible to pull them off of the circuit board.
  • The face plate can now be removed from the body of the radio. Gently pull on the face plate to separate it from the radio. It might require a little bit of wiggling to remove.
  • Be careful when removing the front panel. The connectors inside are known to have weak solder joints, and it is possible to pull them off of the circuit board.
Insertar traducción aquí
