Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 7
Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly. Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first. Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
Open the inner assembly
  • Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
  • Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
Gebruik een nagel of een openingstool om de onderste plastic module van de schermmodule weg te duwen.
Scheid de onderste module nog niet volledig van de schermmodule. Er is een kabel die beide met elkaar verbindt.
