Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 7
Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly. Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first. Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
Open the inner assembly
  • Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
  • Do not completely separate the lower assembly from the display assembly yet. There is a cable connecting the two that must be disconnected first.
Usa una uña o herramienta de apertura para levantar el ensamblaje inferior de plástico del ensamblaje de la pantalla.
No separes aun completamente el ensamblaje inferior del ensamblaje de la pantalla. Hay un cable que conecta los dos que deber ser desconectado primero.
