Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Apply a suction cup as close as possible to the edge of the display. Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
  • Apply a suction cup as close as possible to the edge of the display.
  • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
  • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
  • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
  • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
Insertar traducción aquí
