Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 47 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
During reassembly, gently push down the center of the lower case to reattach the two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips.
  • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  • The lower case is connected to the upper case at the center, with two plastic clips.
La tapa inferior se une con el cuerpo en el centro, con dos clips de plástico.
Durante el reensamblaje, empuja suavemente hacia abajo el centro de la tapa inferior para volver a sujetar con los dos clips de plástico.
[* icon_note] The lower case is connected to the upper case at the center, with two plastic clips.
[* icon_reminder] During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
[* red] The lower case is connected to the upper case at the center, with two plastic clips.
