Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Paso 2
Remove the following 14 screws (some models may be missing a couple of screws):
  • Remove the following 14 screws (some models may be missing a couple of screws):
  • One 2.5 mm Phillips.
  • Six 3.5 mm Phillips.
  • One 4.5 mm Phillips near the sleep light with a small shaft.
  • Two 4.5 mm Phillips with larger shafts.
  • Four 5 mm Phillips
  • If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
Insertar traducción aquí
