Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 2
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding. Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove. Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
Safety Requirements
  • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
  • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
  • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
  • Wear eye protection. The knife or glass may break, sending pieces flying.
  • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
Debido a que el espacio entre la pantalla y el cuerpo del reloj es tan delgado, se necesita una cuchilla afilada para separar ambos. Lee las siguientes advertencias cuidadosamente antes de continuar.
Protege tus dedos manteniéndolos completamente alejados del cuchillo. Si tienes dudas, protege tu mano libre con un guante pesado, como un guante de cuero o un guante de jardinería.
Ten cuidado de no aplicar demasiada presión, ya que esto podría causar que el cuchillo se deslice y le corte, o dañar el reloj.
Usa protección para los ojos. El cuchillo o el cristal pueden romperse, haciendo que los pedazos salgan volando.
No dudes en colocar o quitar la correa del reloj según sea necesario para tener más control al hacer las reparaciones.
