Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 9
Use an opening pick to lever out the antenna cable assembly in the areas shown. Don't slide the opening pick from side to side, as there are two display cables in the way that may be damaged. Don't slide the opening pick from side to side, as there are two display cables in the way that may be damaged.
Unseat the antenna assembly
  • Use an opening pick to lever out the antenna cable assembly in the areas shown.
  • Don't slide the opening pick from side to side, as there are two display cables in the way that may be damaged.
Usa una púa de apertura para extraer el ensamblaje del cable de la antena en las áreas que se muestran.
No deslices la púa de apertura de un lado a otro porque hay dos cables de pantalla que pueden dañarse.
