Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Slide the opening pick along the edge of the battery to loosen the adhesive. The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive.  Apply the iOpener for at least two minutes. Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
  • Slide the opening pick along the edge of the battery to loosen the adhesive.
  • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
  • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
  • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
  • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
  • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
Desliza la púa de apertura a lo largo del borde de la batería para soltar el adhesivo.
El adhesivo que mantiene la batería en su lugar es suave. Sin embargo, si tienes problemas para sacar la batería, puedes colocar un iOpener caliente en la parte trasera del reloj para aflojar el adhesivo. Aplica el iOpener durante al menos dos minuto
Usa una presión constante y constante para levantar lentamente la batería, separándola del adhesivo que la fija al tablero del sistema.
Cuidado con los cables de la pantalla y especialmente con el cable Force Touch que cubre la batería en una esquina para no dañarlos al sacar la batería.
Asegúrate de no perforar o deformar la batería, ya que puede incendiarse y/o explotar si se daña.
No intentes quitar la batería por completo todavía. Todavía está conectada al ensamblaje del reloj.
