Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 9
Gently work the card deeper under the battery cell to break up the adhesive securing it in place. This should not require much force—the adhesive remover does most of the work. If you aren't able to get your card under the battery cell, apply a bit more adhesive remover as instructed above and wait 2-3 minutes before trying again.
  • Gently work the card deeper under the battery cell to break up the adhesive securing it in place.
  • This should not require much force—the adhesive remover does most of the work. If you aren't able to get your card under the battery cell, apply a bit more adhesive remover as instructed above and wait 2-3 minutes before trying again.
Introduce suavemente la tarjeta bajo la celda de batería para romper el adhesivo que la asegura en su lugar
Esto no debería requerir mucha fuerza, el removedor de adhesivo hace la mayor parte del trabajo. Si no puedes meter la tarjeta debajo de la batería, aplica un poco más de removedor de adhesivo como se indica arriba y espera 2 ó 3 minutos antes de volver a intentarlo.
