Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Using the previous step, orient the new drive so that its SATA connectors will align with the enclosure's. Slide the drive into the enclosure's opening. Push the drive into the enclosure until it stops sliding and the SATA connectors are completely seated.
  • Using the previous step, orient the new drive so that its SATA connectors will align with the enclosure's.
  • Slide the drive into the enclosure's opening.
  • Push the drive into the enclosure until it stops sliding and the SATA connectors are completely seated.
Usando el paso anterior, orienta la nueva unidad para que sus conectores SATA se alineen con los de la carcasa.
Desliza la unidad en la abertura de la carcasa.
Empuja la unidad dentro de la carcasa hasta que deje de deslizarse y los conectores SATA estén completamente asentados.
