Saltar al contenido principal
Inglés
Holandés
Paso 10
Removing the backlight guide panel from the device grants us access to the motherboard/battery/vibrator assembly. Much like the ribbon cable, three components make up this assembly, held together by very delicate soldering. If any one of them fails (most significantly the battery), they will all need to be replaced as a single unit. Much like the ribbon cable, three components make up this assembly, held together by very delicate soldering. If any one of them fails (most significantly the battery), they will all need to be replaced as a single unit.
  • Removing the backlight guide panel from the device grants us access to the motherboard/battery/vibrator assembly.
  • Much like the ribbon cable, three components make up this assembly, held together by very delicate soldering. If any one of them fails (most significantly the battery), they will all need to be replaced as a single unit.
Insertar traducción aquí
