Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 7
Carefully disconnect the three antenna coax cables by prying them straight up from the logic board. Slide your tweezers or the pointed end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it. To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
Disconnect the antenna cables
  • Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
  • Slide your tweezers or the pointed end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
  • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
Desconecta cuidadosamente los dos cables coaxiales de la antena, sacándolos directamente de la placa lógica.
Desliza tus pinzas o el extremo plano de tu spudger debajo de cada cable hasta que esté cerca del zócalo, y luego suavemente gira o haz palanca para desconectarlo.
Para volver a conectar cada cable, alinea el conector directamente sobre su zócalo y luego presiona hacia abajo para que encaje en su lugar.
