Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 3
Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board. Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
Disconnect the trackpad
  • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
Usa un spudger para desconectar el cable plano del panel táctil levantando cuidadosamente su conector de la placa lógica.
