Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 13 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
Use a spudger to gently lift the battery power connector, disconnecting the battery. Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Disconnect the battery
  • Use a spudger to gently lift the battery power connector, disconnecting the battery.
  • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Utiliza un spudger para levantar suavemente el conector de alimentación de la batería, desconectando la batería.
Levanta el conector lo suficiente para que se mantenga separado de su enchufe. Si accidentalmente haces contacto durante el transcurso de la reparación, podrías dañar tu MacBook Pro.
