Saltar al contenido principal
Inglés
Español
Paso 5
Our testing shows that the Taptic Engine and main speaker are interchangeable between the 8 and SE! That means fewer parts to hunt down and cheaper replacements, which is a win for everyone involved. Turning to the battery, the capacity is the same as in the iPhone 8, ringing in at 6.96 Wh. That's up slightly from the original SE's 6.21 Wh, and much lower than the (much larger) iPhone 11's 11.91 Wh.
  • Our testing shows that the Taptic Engine and main speaker are interchangeable between the 8 and SE!
  • That means fewer parts to hunt down and cheaper replacements, which is a win for everyone involved.
  • Turning to the battery, the capacity is the same as in the iPhone 8, ringing in at 6.96 Wh. That's up slightly from the original SE's 6.21 Wh, and much lower than the (much larger) iPhone 11's 11.91 Wh.
  • When Apple retired 3D Touch in the iPhone 11 Pro series, they made the displays a bit thinner and batteries a bit thicker. The new SE also lacks 3D Touch, but the batteries are the exact same size. What was the sacrifice for?
  • Answer: Probably to save money and hit that sweet $399 price point.
  • Alternative answer: Apple wants us to forget that 3D Touch ever happened. We remember.
  • Unfortunately, though the batteries match in size and capacity, the connector has changed—meaning that batteries cannot be swapped between models, unlike the other components seen here.
Nuestras pruebas muestran que el Motor Táptico y el altavoz principal son intercambiables entre el 8 y el SE!
Eso significa menos piezas que buscar y reemplazos más baratos, lo cual es una victoria para todos los involucrados.
En cuanto a la batería, la capacidad es la misma que en el iPhone 8, sonando a 6.96 Wh. Eso es ligeramente superior a los 6.21 del SE original, y mucho menor que los 11.91 Wh del iPhone 11 (mucho más grande).
Cuando Apple retiró el 3D Touch en la serie iPhone 11 Pro, hicieron las pantallas un poco más delgadas y las baterías unpoco más gruesas. El nuevo SE también carece de 3D Touch, pero las baterías son exactamente del mismo tamaño. ¿Por qué fue el sacrificio?
Respuesta: Probablemente para ahorrar dinero y llegar a ese dulce precio de 399 dólares.
Respuesta alternativa: Apple quiere que olvidemos que el 3D Touch alguna vez sucedió. Lo recordamos.
Desafortunadamente, aunque las baterías coinciden en tamaño y capacidad, el conector ha cambiado, lo que significa que las baterías no pueden ser intercambiadas entre modelos, a diferencia de los otros componentes vistos aquí.
